How many VFDs to share a load ?
Skyba
Sep 2013
Lima, Peru
Hi everyone,
I have a project in which I need to lift a cylindrical tank of 20 tons with a dozen 0.5 HP motors over 15 minutes. It's important that the load distributes evenly over every motor.
What is better :
1) 1 VFD for 15 motors, control in V/f mode
2) 3 VFDs with 5 motors each, control in V/f mode
3) 15 VFDs with 1 motor each, and interconnect the VFDs for Torque/speed share.
In the first two options, i would protect every motor with a thermal overload. Option 2) has two sub-options, see http://img845.imageshack.us/img845/2486/yyra.png. Do you know which is best for a good load share though "slipping" of the motor ?
Option 3) is pricier and more complex. Only in last resort.
Thank you very much for your help !
Bas
Option 3 is going to be the best and most reliable and easiest to maintain.
Vendor selection would be critical though.
I would only consider Rockwell,Siemens or ABB likely Rockwell or ABB. With Rockwell I would use 755 series with CIP Sync and CIP Motion.
Just my 2 cents.
With multiple motors on a single VFD, you cannot manage individual motor torques. The variations in mechanical friction and especially variations in the motor slip/torque relationship will make torque management impossible.
If you want to be sure to load each motor equally, individual VFD's with torque follower control signals will be required.
My choice would be ABB ACS800 drives due to the precision of the torque management and the response speed if something gets unbalanced. Also, you should be able to do this job without encoders on the motors.
Good Evening , We have a number of Powerflex 525 Drives . I took notice for years elsewhere and our plant , that our Powerflex 525 drive...
642
Good Afternoon, Just wondering , are many of you using SAP in your plants ? If so , is it difficult to learn ? Are there many training...
1,423
It better to have too many instead of not enough right?
26
2,899
Hi all- I have an application where: - I have a fixed system with a pre-determined, static, network (say, 192.168.2.0/24). - That system...
4,241
I have an application that needs 20 inputs and 20 outputs with only 10 XNOR and 10 NAND blocks. I could do it with relays, but this could end up...
5,174
