How SCADA read PLC tags from s7-1200?
kerolarifen
Sep 2014
Kajang
Hi all..
i would like to ask about the scada and s7-1200.
currently, i'm using Integraxor scada and CPU 1212c.
in my situation,
my PLC will be at a river in order to monitor the water level.
my scada will be a the control centre.
both of them will use the GSM modem that support the port forwading.
during the demo, i set the PLC ip : 192.168.0.5
scada ip : 192.168.0.33
both of them using the same network.
on the scada, it will read the PLC tags using port 102.
it work perfectly.
now, i need to separate them and using the internet.
PLC WAN ip : 183.171.208.194
Scada WAN ip : 183.171.208.195
i already set the port forwarding in GSM modem.
and the scada need to read the PLC tags using 183.171.208.194:102
but i failed to connect it.
it said the port is not opened.
yes, i'm sure
thank you for your reply Rouan.
i'm very sure that my ISP doesn't block the port forwarding because i can use others port forwarding for cctv.
Hi, I have a question, Can cygnet scada system read/write Rockwell controllogix PLC UDT Data? Does it have OPC client? Thanks a lot!
4,446
Hello, Just wondering if it is possible to make internal CitectSCADA project tags available to an OPC server. (Schneider OFS). There are...
923
Hello, I have a AB Powerflex 700 VFD drive that I have connected to our network via a CAT5 cable to a switch. I would like to read various...
2,348
I have a client asking for an inductive automation IGNITION SCADA system for a new lab in which they will test various engines that use a variety...
2,447
How to read and write text file in Citect Scada? I want to write to text file when engineer change the set point. I want to get that changed...
4,031
