How should I match a combo control unit and a sensor
If the controller has 24VDC PNP ? Inputs, then your sensors should be 24VDC PNP.
I could not confirm if the inputs are PNP, but my guess is that they are.
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
426
Hi, I am working on automating an industrial fabric shrinkage tester to replace its outdated electronics with a PLC. To get the tank's water level...
17
775
In a control System, I need to move 3 motors attached to roller in stages with speed of 1 to 2 RPM and the torque of motor should be 8-10 Nm...
839
Hi, I want to build a production line project using a PLC. This is the project page...
2,260
See picture. I want to add a rung (magenta) into the existing code. Can't figure out how to do this. I select a -||- , right? When I drag/drop...
21
1,858
