Magic 8 Ball
the computer chip enchants me and piques my interest... what did they leave out of the com port on the hmi? driver hardware?? sufficient current capacity??? makes ya wonder sometimes.
rsdoran said:Either channel on this ML is capable of DF1, may try using one of AB's port splitters. I have no idea what effect it may have when the modem is in use tho.
Magic 8 Ball said:the computer chip enchants me and piques my interest... what did they leave out of the com port on the hmi? driver hardware?? sufficient current capacity??? makes ya wonder sometimes.
Bytesize said:That would work but we need to connect to the 8way DIN because our modem is connected to com port 1
rsdoran said:That was what I was refering too, using the port splitter for com 1 to share it between the modem and HMI, just not sure what effect it may have.
Magic 8 Ball said:The 1747-DPS1 RS-232/DF1 port
splitter allows a single RS-232/DF1 port
on a Rockwell Automation controller
(e.g. SLC™ 500, MicroLogix™, PLC-5®,
ControlLogix®, CompactLogix™) to be
expanded (or split) for communication
with two external devices at the
same time.
From a single DF1 port, the splitter
creates one full-function port for twoway
communication between the
controller and a local network. The
second port is respond-only and is
primarily designed to run a programming
terminal or human machine interface
(HMI). Both the initiate/respond, and
respond-only
the one full function, and one not, may be an *** biter...
diagram on 1747_pp018A doesnt show a modem at all.
RSDoran said:know if it has all of the 8 pins wired?
OkiePC said:So, GIT, do you have access to the 8 pin connector that fits?
