how to add new sensor for asi-distribuctor
vpmsarvananr
Sep 2011
singapore
22
i have 4 port “asi-distribuctor" available, so already 3 sensor used that port,, one consider standby, so I will plan to use the port, all sensor got own program (that means address),
Now I add 1 sensor and assign one program (address), but unable to get signal from sensor, I checked ladder logic also can’t see the signal,
How to communicate with plc
any bady know answer please share me friends,
Thank you
Saravanan.
Message body Hi, We have a simatic field PG which we use for the s7-300 PLC's.in my process I need additional add one sensor . Currently my...
1,596
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
137
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
138
Im trying to create a level indicator for water Tank i have used the ADD function while the pump is on and level increasing everything works...
33
1,111
