How to assign ASI slave adress in plc
Sir the problem with ASI slave , if new asi slave addressed and connect with network means continous error will come in slave ,if power also turn off and turn on
This reminds me much of a quiz.
My next questions:
3: Which version no. of Step7 do you use?
4: What is the MLFB-number of your 343 ?
5: In HWConf; if you click on the 343, do you get a tab called 'Slave configuration'?
Please put corresponding numbers in front of the answers. It will be easier for us to interpret.
Kalle
3. Step 7 version is 5.3 and SP1 4. 6GK7 343-2AH00-0xA0 5. If click CP 343-2 only General and address available.
Okay. I never saw or touched this card type. I recon it's better that you read the manual than I.
Good luck!
Kalle
Edit: Rightclick on the card in HWConf and you'll find a shortcut to the manual on Siemens websites.
I have 32 masters in a linear topology network chain. I would prefer to use AL1xxx series from IFM. They do support device level ring if that...
1,056
On my HMI-1200, I'm trying to assign the image of a floppy disk ("save" icon) to a function key. I couldn't find one in the default drop-down...
612
Hi everybody. I got some problems about how to perform this task Now, I got an FB where I have this code snippet that looks like: L P##DBD_134...
1,146
Good Morning, I'm not sure if this is a stupid question, but I've been working with FTView ME for quite some time now and I can't solve this...
1,502
Hi I have a few Movimot motors on profinet, where i need to change the profinet name on the motor. I have been true this before, where i deleted...
2,451
