How to change case using WinCC script
Maia
Sep 2004
Laguna
29
Hey guys,
Can someone help me create a WinCC C script so that user login name is converted to lower case? I created a script that triggers a tag whenever a user logs on. Its working except when a user logs on in a different way than what was programmed (i.e. if I programmed tag1=1 when user maia logs in, tag1 will not activate if I log in as Maia). I was told to use TOUPPER or TOLOWER C command but I don't know how to put it in a script.
Please help.
Thanks,
maia
Hello everyone, Who knows how to implement constants in CASE loop via address to do it flexible. I show it on screenshot. Thanks a lot.
53
15,871
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
225
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
120
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
253
Greetings I have a problem, my system is the following: wincc v8.0 (demo), logo8.3, abb m2m analyzer. I created some pages to display the...
89
