how to communicate omron plc cj2m with wonderware
mustaqim90
Mar 2015
SHAH ALAM
hi..
i have done build a ladder program with cx-programming and i want snow the result in wonderware intouch software..lets say i want show a value in memory CIO0008. how can i show this value in wonderware?. how to communicate between omron plc and wonderware?
I have some question again Experts :)
My 2 cj2m plc need to connect to wonderware intouch scada but I dont know the configuration setting.
Can you tell me what is the third party software need to install in communicating cj2m to wonderware?
Also I need again ah step by step configuration setting of the third party software?
Thank you your reply is highly appreciated.
omron interfacing with intouch
you need to install OMRONHL software.it is a interfacing software for omron plc.
After installation open this and in topic defination add new name (what you want),comm port according to your computer,model no. C200H, plc series no.,interval-1000ms
then in wonder ware click on switch,in switch type select i/O discrete
access - give any name
application name- omronhl
topic name- as given in omronhl software
protocol-DDE
item for memory -CH01000....CH01001 like this
for output - CH10000....CH10001 like this
Hi, I am attempting to upload a program from a CJ1M Omron PLC using a USB-serial converter. My co-worker was able to upload the program on to his...
3,925
Hi, My lecture assign a project to us, but is over ours capability seeking help from you guy. He want us to make one check weighier using plc...
2,854
Hi there, can s7-300 plc communicate with any omron PLC through Ethernet? i had two old omron plsc installed, one is c200he cpu42, the other...
4,591
V
Hi, What do I need to communicate with PLC Omron from my PC by Visual Basic application?
6,026
Hi All, I aim to use Aveva Plant SCADA 2020 to read and write data from/to Omron CJ2M CPU35 PLC using OMFINS protocol. However I have Bad Data...
732
