How to connect a Siemens S7-400 CPU to a SQL database
Frans Larkins
Sep 2012
Ngodwana
We are starting a project using a Siemens S7-400 CPU and must write data to a SQL server. We are also running a WinCC Server. Can the WinCC server connect to the SQL database or must we run separate OPC software to make a connection?
Thanks for the reply. The SQL database that the data needs to be stored in is running on a Seperate Ethernet link to our IT Network. I am not sure how we will get the data into their server. They want me to write into their database and create a new record each time? Do you perhaps have an idea on how to do it?
It is called "Taglogging" in WinCC v6-v7.
I am sure that WinCC can write to a separate SQL database. You have to read the manuals (!).
I only have superficial knowledge about WinCC v6-v7 so I dont know about in details.
There's no built in/standard functionality to connect to a 3rd party SQL.
But using the scripting system/options, you can connect to a 3rd party SQL to read/write.
We used 'simple' VB scripts to connect and exchange data.
342
Sorry for the basic question: At the moment, the PLC [S7-1200] is connected to a laptop (contains TIA Portal) via the ethernet port. When I add...
1,535
Hi Complete newcomer to S7 so go easy on me... Siemens S7: What cable do I need to connect S7-1200 PLC to HMI? The touch screen is one of these...
2,632
Dear guys, I have a software that sends data to PLC using modbus. I want to connect my software with siemens plc, how can i do that?
19
4,738
Hi - I have an application where we are planning using an Edge device to connect some equipment, likely an S7-1500 and WinCC Unified Comfort...
953
