how to convert controllogix majorfaultrecord to character?
wilsonzhu
Jan 2008
vancouver
278
Hi All,
For some reason, I had to clear the recoverable major error in the fault hander routine and record the fault for history check, The MajorFaultRecord is consisted by time_Low, time_High, type, code and info[8] array, I want to convert time_Low, time_High and Info[8] array to the readable ASCII Character. Could you please give me some advice.Thanks.
I mean how to access major fault log(displayed in the Recent Faults area of the dialog) in the Controllogix fault hander routine if it's possible, because it's already clear the fault in the program, but I want record for history check.
Hi All,
Hi Wilsonzhu
Want to know if you find the answer of your question. I also need info about the convertion.
How is the correct way to convert a Controllogix program from version 20.11 to version 30? I have already flashed the processor to version 30 but...
2,693
Jees... Continuing from this thread... http://www.plctalk.net/qanda/showthread.php?t=85341 I now have the correct pressure in Torr and mBar...
24
7,425
I have a Panelview 1000. Originally its was communicating to a PLC5. I replaced the PLC5 with Controllogix. I have converted the PLC logic to...
19
10,365
2,406
Hi all. I have a working program from a compactlogix platform that I have to convert to an existing SLC500. I am rewriting it manually at the...
4,287
