How to copy the fixed local data in an OB?
tonus
Apr 2009
Europe
This may sound academic, but just for the sake of my understanding, I would like to copy the fixed part of local variables in for instance OB80..OB100.
That fixed data field is commonly 20 bytes long but its types may vary depending on the OB-number.
What is wrong with an any-pointer constructed from this STL data B#16#10020014000086000000 say MyPointer and an integer MyResult followed by: CALL "BLKMOV", SRCBLK:=MyPointer, DSTBLK:=P#M100.0 BYTE 20, RET_VAL:=MyResult. MyResult will end up in B#16#8124.
The MyPointer is intended to point to twenty bytes of data starting at the beginning of the local stack in a S7 OB-block.
:eek:
Replace the 86 with 87
Thanks, giving it a look.
But then I consider what is the difference between #86 local data and #87 previous local data? đź“š
And, yes indeed #87 gives results. 🍻
By the way I have no idea what should be in the first accu after loading your acronym.🤷
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
112
I have 2 7cp476 plcs. How can I copy one of them and install it somewhere else?
93
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
179
Hi everyone I'm in a bit of a conundrum, I've been trying to get this HMI on our machine and I am unable to retrieve it. Device Delta Model...
1,018
Hi I have a Melsec FX1S-20MR, which has been programmed. I would like to copy the program to a new FX1S-20MR? What are the possible ways to do...
668
