How to do retentive memory in 313C-2DP
uptown47
Feb 2008
Over there, next to those boxes
1,146
I want to have a retentive marker word in a 313C-2DP. I have set up retentive memory in the properties of the PLC in the hardware config to be 16 bytes starting with MB0 but when I power the PLC down and back up it seems to lose whatever I've put in MW2 ?
I wondered if I need a battery for the PLC and (if so) where does the battery go ??
Many thanks for any light you can shed on this
Hi Ivo,
Sorry for the late reply, I've not been on the site for a few days.
My mistake, the retentive memory is working fine. I was viewing the wrong MW and the problem is sorted now.
It was a 314-6CG03-0AB0 by the way.
Has anyone experienced any retentive memory loss on recent Red Lion Kadet screens (G307 in particular)? The equipment in question has a G307K200...
2,114
Hello everyone, I'm facing a problem with the retentive property of the allocated memory. I'm using bits (BOOL) of some %MW allocated registers...
2,730
I need to backup some %MWi varibales in an M340 program without stopping the PLC. Any ideas? Also what is the Save Variable attribute used for...
2,417
Hello, I need use retentive memory in a Rockwell Micrologix 1100 to save the value of some variables and the state of some counters when the power...
3,545
Hello people. How do I make some memory area keep the values on a power outage. I'm using the set command on a coil, when I cycle power it goes...
5,262
