how to do the PID simulation in Honeywell PKS demo environment
pointgrey
Nov 2015
Houston
Hello,
I am learning Honeywell PKS on a PKS R311 virtual machine. I built a PID CM and loaded to the simulation.
Does anybody know how to make the PV or SP change to see how the OP responses under PID CM simulation mode?
The CM screen are attached and please guide me.
Thank you very much.
PT
Normally you would set pvsource to manual then enter the pv you want the input to have. That's done on the analog input or on the PID controller itself. SP (setpoint) value is just to set to whatever you want on the PID controller. PID has to be in auto to do any work.
I haven't used the demo environment but this is how it's done when you want to simulate something in an actual process.
Thank you Pete for your tech support. I figured out that I had to change some parameters of the PID block to see the output in simulation mode.
106
There has been quite a lot about PID programming & simulation recently & I thought some people might like this idea, it is a bit Heath Robinson...
1,003
Hello, I have been developing a library of function blocks. One of the developed function blocks is the PID controller. I have created a Simulink...
3,008
Would anybody know how I can simulate the PV of a PID function using the output of the PID itself? I have seen it done before using an integrator...
2,611
Hi, I am new to Mitsi and I'm working on a project that will use a few PID loops. I do not have the hardware in the office so I am using the...
3,678
