how to get the instance number of a structure template?
chenhg
Sep 2008
Shanghai
26
hello all:
I was wondering if someone might be able to help. I have been confused for several days.
I write a OPC server and want to read a UDT tag.Firstly I want to
use the Get Attributes List Service(0x03) to get some information for the template ,however i don't know how to get the instance number of the template,and the attribute ID information .
anyone can help me ,thanks a lot.
Does anyone know how to make CFC editor/compiler to create same instance DB number for modified CFC chart objects? Sometimes, after change...
5,149
Exposing shades of “newbie”…. I haven’t used arrays much, and I think using one for multi-zone temperature control is probably the solution I...
814
Hello, PLCS.net guys. I'm learning about MSG for TCP communication recently. I'm trying to use CIP Generic. And the main flow is like the one...
1,265
Is there any way to use a tag value in the Instance Name field? I would like to have an array of strings with my module names that I can loop...
970
I'm hooking up a scale to an EWEB card on a 1756 PLC through ethernet/IP sockets, and I've run into an issue that seems to defy ladder logic. See...
2,699
