How to make a dynamic tag for WinCC Alarm Logging using C-Script
D.Scorgie89
Nov 2013
Johannesburg
Hi All,
What i am trying to achieve is a dynamic tag(Device_1)[Text tag 16 bit] that monitors the state of another tag (Config_1)[unsigned 8 bit] in order to change its text description.
This tag (Config_1) has 23 possible states that all need to be represented in a text format. These states are all numerical but i need the numerical to trigger a text.
i.e.
0 = Relay
1 = PLC
2 = Analog
So as the state in Config_1 changes i need the text in Device_1 to change. I have tried doing this in C-Script through WinCC but C is not my strong point.
I tried using the GetTag[]state and SetTag[] functions but to no avail. All online searches haven't given much assistance.
Please Help.
Hey Guys! Wondering if anyone here knows if it's possible to address area blocks in a PLC via pointers in WinCC Flexible. I need to...
4,537
I have spent multiple hours looking for a solution for the following problem. I have an HMI application that is meant to be installed at 3...
1,214
I have never used a RedLion HMI before, but I am fixing to. I have three identical yet separate processes where each will have its own RedLion...
1,715
So I am currently trying to create a data-viewer within FT View. I need the operator to be able to select two different datasets from a list of...
1,332
We have a hoist still running a 1336 series drive. Having trouble slowing it down with a heavy load. I noticed the two dynamic brakes have...
48
