How to read User Defined data with CIP?Thanks
chenhg
Sep 2008
Shanghai
26
Hello all:
I have use 4C and 4D services to read/write atomic data or array from/to CLX5000 successfully.Now i want to read UDT(user defined type)data.I can read a struct tag wholy to my OPC,but no idea to know the member name and the member type for OPC client to read member data within a struct tag. I have the logix5000 data access manual, and want to use 52,03 service to implement it,however, i am so stupid to understand the following doubts:
(1) Read/Write Data Fragmented Foemat Service is for what? i use this service to read a array SINT[3] BY "53 03 91 04 53 49 4e 54 01 00 02 00 00 00"(the byteoffset is 2,size is 1),the response is wrong.
(2) the "tt" (instance number) of the Get Attribute List Service command is what and where to get it?
I am so confused ,any help will be appreciated,thanks.
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
180
Is there a way to use the FAL instruction to do +=2 instead of +=1? I have an array that is organized with alternating "data" and "flag" values...
139
Hi everyone i have a customer, who wants to show an alarm on the machine, if the I/O forces are enabled and set, on at ControlLogix L81E with...
271
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
109
Hi everyone. Quick questions. On UnityPro, I want to open and quickly read tags from a .STA files witouth opening the program. I have 30 plc...
162
