How to repair PLC 1215 DC/DC/DC
arkngl2102
Jul 2015
Mexico_City
36
I have a S7-1200 PLC [1215 DC/DC/DC] but someone want to sell me, problem is PLC was connected with 127v once.. and now PLC no turn on.. its posible repair it ????
thanks in advance for answers...
If I was buying a PLC to tinker/practice with, I wouldn't care if it had been previously repaired and appeared to work OK.
If I was using it to run production on a machine, I'm not so sure I would trust it. It is entirely possible that you could get it to go into run, but maybe it calculates 1+1 as 3 now, instead of 2.
It's likely possible to repair, the question is, how much will it cost and will it end up costing you more than buying a functioning one? And that's something nobody can tell you without opening it up on the bench and having a detailed look at what's been damaged.
What is the normal designed input voltage for this unit? If it was designed for 24VDC, then, it could be a protection diode and/or an internal fuse failed in the power supply. Of course, it could have burned up a portion of the printed circuit board and just can't be easily repaired. As ASF has recommended, I would take it to someone that has basic electronic repair knowledge to look and evaluate/diagnose the power supply for the unit.
Hi thanks for all answer and comments.. now repaired:
problem was Diode.. but now works fine.. only i will use to test, not for operational machines..
i hope this help to others..
Hello! My name is Luke and I started training about a month ago at a company to repair and remanufacture PLCs. I've done a lot of training and...
1,669
All, I am looking for a replacement blue indicator for an small plc trainer box that has an AB micrologix 1000. See picture. I am sure many of...
6,178
I have an output card out of a Fuji plc that needs repaired, any recomendations on the best place to send this? The card is no longer avalable. Thanks
1,888
Hi all, A customer of us had a problem with an Allen Bradley CompactLogix. He called Allen Bradley tech support, followed some of their...
20
7,755
2,231
