How to report to operator a problem writing database?
Desmoke
Nov 2013
Italy
the architecture of the control system ​that I'm using is the following:
FTView Local Station 7.00.00 (SR CPR9 6) on machine running XP. The Client runs on the same machine going to define an Stand Alone architecture .
I'm using also RSLinx Enterprise data connection to a PLC (1769-L30ER).
It's been configured Datalog model of Oracle Database that records the data correctly. The DB is installaed on another machine with Xp.
If for one reason generic, the recording data is not to be successful, (eg. network problem, a disconnected cable, whatever ...), I need to notify the operator through the activation of a bit, which then I will use to activate a siren alarm, and a warning light.
Any suggestions on how I can proceed??
I had a student fooling around with settings tonight, and now when I try to print a program ladder, each rung prints on a separate sheet. Too many...
361
Hello, I was looking for some advice. Is there functionality within WinCC (V7.5) to report , list or export all tags that have been used within...
420
Hi guys, Is it possible to automatically generate PDF Report of Trend and Datalog in FactoryTalk View SE v12? If YES, Please, how?
685
Could I ask what the FW column signifies on the file memory usage report on RSLogix 5.
1,704
I've got an M340 hitting an Ethernet to Serial converter one read at a time. Each read is enabled through a one-shot r_trig. I've got some extra...
1,607
