How to return SQL data to Citect
Alien
May 2012
Singapore
I had issue on return SQL queries data back to citect!
Any expert knoe which cicode command to use for this?
i had tried
"PLUSADOGetRowFieldText(INT hADODataSet, INT nRowOffset, INT nFieldIndex, STRING sNullValue)"
but nothing happen nor any data been retunr to citect.
Help plsssss.
Thank..
I have a Type C to RS485 adapter connect to my Siemens RWF55. I use modscan to scan it to get a value from the Siemens controller. In the...
104
This is for editing HMI texts en masse in Excel. My problem is that in my HMI texts, some are in multiple lines, even if they are single texts...
26
9,153
Hello, I have been tasked to create routines that has a JSR with zero return parameters to go to a routine with a RET with zero parameters. Is...
1,417
Hi all, I have a PIDE block (Logix5000) where I am introducing interlocks. I am using the ProgOverrideReq to set the CV to 0% (shut a control...
1,643
I am using Indusoft Version 8.1, and trying to use the VBScript button command to find a string in a column in a MySql database, and return all...
36
8,754
