How to Send Message from MicroLogix 1100 to ControlLogix?
LuCyLut
Jun 2006
Michigan
Hi Everyone,
I'm a college student working on a program for mircologix 1100, very new at this! Can somehow help me on what can should I do to send a message from Micrologix 1100 to Control logix and where can I set this up? I have the ip address and slot # and address of where I want to send the message to...but have no clue where can I do that in my program. I'ld appreciate the help. thank you!
Welcome to the field.
Read about your MSG command in the online books.
There is alot of information to cover, so here is the basic idea.
Insert the MSG command into your logic somewhere. (Timer drive it for starters)
Use the pulldown menu inside the MSG block and it will open up another window. Here is where you set all of the applicable TAG's and IP addresses. CIP/Whatever.
This is a start.
LuCyLut said:
Hi Everyone,
Try the AB Knowledge base. There is an example in there somewhere. I printed out and used it last week. In the knowledgebase search for something like SLC Message, MLX Message, MLX Ethernet, CLX Ethernet.
hi I wanted to know if it was possible to exchange data between two micro820 via ip , I have not found any function that allows this . You know...
1,943
Hello. I´m a plc-rookie and really need help. I have a Siemens 312 PLC , CP 340 rs232 card and an Epson cash display. I want to send a counter...
2,609
I want to type a message on hyper terminal and send it to Micro controller by using Rs-232 serial cable. Can any one tell me how to do this ...
2,050
Dear all, I have following problem. I'm sending an SMS when i got an alarm. For now I'm sending "Temp to high" but now i want to change this...
3,882
