How to size a circuit breaker for a panel?
Pxp30
May 2003
Hi everyone,
My question is where can I find information about sizing a circuit breaker for a panel that includes a 3 phase, 250 HP DC drive, Plc, and other little components. This drive puts out 405 FLA,500VDC and draws from the AC supply about 340amps. The charts I've found for sizing the breaker covers are only for squirrel cage motors. Is there a good web site or book I can find this info? Also is there a formula for this, like 1.5 X FLA?
I would use just a disconnect and fuses for circuit protection but the customer demand a circuit breaker. Is it necessary to use it with a proper DC drive package?
Sorry my question may not be appropriate for this PLC forum, but with so many experienced control guys here hopefully can help shed some light to me. Maybe someone can direct me to a site for controls similar to this one. Thanks.
The National Electrical Code is the answer to your question for sizing CBs or any other electrical apparatus for that matter. Also, you might try this site http://www.patchn.com/forum/ for getting better response due to the topic you have. The above site is for Industrial Maintenance type questions and everything connected with it. There are some really good experts there as well. Hope this helps!
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
242
Hi, I'm working on Mitsubishi MR-J5-70A amplifier, and need some advice on selecting fuse size. Main power is 1ph 240VAC, and in the manual, it...
104
Hello, I have a quick question. I have been using scripts to change the color of buttons. The reason, I am usually using multiple hmiruntime.tags...
129
Supposing I want to be put a TIA Portal Project "executable image" onto a memory card (e.g. see picture). The reason for doing this is so that I...
395
Hi all, I am having an issue with FT View Studio ME when I try to open the propoerties of any object, the size of it is very big and doesn't let...
111
