How to transfer data from one OP15 to another one???
Kubas_K
May 2011
PRAGUE
Good day to all,
i have in my possess SIEMENS PANEL 0P 15-C2. I have accidentally unplugged battery and lost all program. Fortunately I have another one which is completely the same. Is there some way to copy data from one to another including firmware?
An early reply would be appreciated
Do you possibly mean the battery in the PLC ?
The program in an OP15 is normally not retained by the battery, but by flash memory. The battery is normally only for keeping the realtime clock.
There is a way to download to the OP15 RAM memory only, but it is only used for short term testing. It is unlikely that it was used when the OP15 was programmed (many many years ago). Therefore, I doubt that the OP15 loses its program only from having the battery removed.
Anyway, OP15 does not support upload to Prosave, so there is no way to transfer the program to another OP15 without the original source program.
So can I somehow by some kind of a software transfer data from functional OP to PC? Then plug OP without program to PC and flash it again?
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
98
Hi all, I am working on a project that with need to capture force sensor data in footplates in order to determine if weight shift is occurring...
527
Has anyone here successfully created a system where the software SAP (ERP) interfaced with an Allen-Bradley PLC? Currently we have to take recipes...
1,123
Is there a way to move a tag value, brought into the panelview via modbus tcp with kepware, back to the plc on eth/ip. IE on the C-Mores we bring...
430
Hello parky, goghie, Brian and all of you who kindly come to help when I get stuck. I cannot look into the clock issue that parki has written for...
862
