srain Member S Join Date May 2008 Location Qinhuangdao City Posts 12 Jun 11, 2008 #1 I use s7 STL to set break point in FC ,but I can't watch variable value ,is anybody can give me some advice ,thanks!
RMA Member Join Date Sep 2004 Location North of Hamburg, Germany Posts 2,052 Jun 12, 2008 #2 Why not copy the temp to a marker variable during testing? Then you can look at it in a VAT. It's possible to update the VAT even when the CPU is in STOP at the breakpoint, I'm not certain, but it might be F7 that refreshes the VAT.
srain Member OP S Join Date May 2008 Location Qinhuangdao City Posts 12 Jun 13, 2008 #3 thank you RMA,that's a good idea!but if simatic has some functions to let us to know the temporary variable ?
L D[AR2P#0.0] Lifetime Supporting Member L Join Date Nov 2006 Location UK Posts 6,703 Jun 13, 2008 #4 When the CPU is in hold, you can inspect the Local data area of the block, for example:
srain Member OP S Join Date May 2008 Location Qinhuangdao City Posts 12 Jun 18, 2008 #5 yes!I'm using this method to inpect the local data now,thanks a lot!
