HSRV Faulting Out
chorn46562
Mar 2004
Indiana
Hello all.
I have an HSRV card in the 2nd slot in the rack. The PLC is a SLC 5/04 we are using. The HSRV, will randomly fault out and I cannot seem to find the reason why. I have changed the HT card and the HSRV card as well as providing a separte power supply for the 5V needed and the card will still fault. Has anyone encountered this before? HELP!!!??
There is a long list of fault codes in the HSRV manual. The code is viewable in the integer file used for the HSRV configuration. Knowing the code should help you out. Does it fault while running or during power-up?
I'll check.
Hello rods87.
Thanks. I'll check those. It faults out while it's running and has faulted out at power up as well. The feedback led lights up at the same time. We have checked the shielding cables and tied them to the terminal and still the problem occurs.
Every morning when I power up the system I get a processor fault. The HSRV card is located in the in slot 2 of the rack. The fault is that it does...
2,456
I have a machine I'm trying to refurbish. Currently, it won't home without intervention. It's using a 1746-L532 processor with two 1746-HSRV SLC...
1,225
I'm looking for someone who may have seen this before I go swapping every part in the system. All of a sudden an existing project started...
1,606
Hi to all. Can someone who have Access Level: TechConnect on Rockwell Automation Support Center Download sample program, and share with me and...
1,994
Hi, I want to use allen bradley's motion control module 1746-HSRV along with the SLC500 controller. I want to drive the Y-series servo motor...
1,229
