hurricane
Unregistered
Guest
U
I'm tring to upload application from AB 1000 panel view,and have the right cable.I can't upload file, for it keeps saying check cable or panelview may be
sending data to printer.I can use same cable and talk to a AB 5/03.I've been away from AB for couple years programming Siemens HMI&PLCS.
My suggestion would be to enter the Configuration Mode. Under Communication Setup look to see what Node the PV is set to. Also check Terminal Info, look at Hardware, it will tell you what type of communication the PV is set for....DH+, DH485, so on.
Later,
Micheal
You might also find that the port you are using has been configured for a printer - again , configuration settings
The cable from a standard serial port to a 5/03 is a crossover ( 2-3, 3-2, 5-5 ). I'm fairly certain the cable to a PV1000 upload/download port is a straight thru cable from a PC serial port.
That's exactly right, Jstolaruk. You have to use a null modem to upload/download to a PV1000 when using a the same cable you'd use to talk to the 5/03.
Sounds like most of Florida dodged a bullet but now our friends just north of there are dealing with some pretty serious winds and flooding. Just...
1,800
Hope all my friends down south are ok and you got out of the way..., we will be praying for you all Looks like its going to be a nasty one
20
7,351
Has anyone tried to salvage equipment that has been under water in floods? I have had pretty good success cleaning with isopropanol and...
1,534
Here's hoping that Phil Melore and others in the eastern part of the United States and their families come through the impending visit by...
4,969
