Hyd cylinder w/ Temposonics
skeet
Jul 2005
Lafayette LA
57
Hey all,
In my sawmill days I dealt with thousands of hydraulic cylinders/Tempo combinations.
It's been a while though, so was wondering: what are some good sources now for fairly basic hydraulic cylinders with a Tempo sensor option?
Thanks!
Mike
Hello, I have a Xinje PLC XC3, where I have the attached program in memory..I don't understand why D1 register increases by 2 instead of 1, every...
22
2,351
I'm looking for the basic schematic symbol for a pressure compensated variable displacement hydraulic pump (swashplate type radial piston pump)...
2,371
can any give me a sample on how to write a program so the my temposonic readout in my cylinder tells my valve to stop the cyl. there and keep it...
2,465
Who makes and all-in-one hydraulic valve that is an I-to-P type device. By this I need to control pressure via a command signal. Not read a...
4,428
I am using Bosch servo hyd valves with Hirschmann (932 460-100) connectors. I would like to purchase a premade molded cable. I have looked around...
2,699
