Hyper-v and USB comm adapter
dwoodlock
Nov 2012
Cincy/nKY
568
Just curious if anyone has any recommended solutions for gaining my USB-A to miniUSB adapter inside my VM
Having an adventure with an M3401000, which has only a USB and serial port on the front of it (this is one reason as I've discovered that vmware wins over hyper-v)
I have found some information about tunneling, where the USB port traffic is converted to TCIP, and can then be read on the VM side(or something to that effect).
Thanks in advance.
You only need connect usb and then select on VMware that usb is connected directly to your virtual PC.
For ethernet and serial connections you can use USB adapters and again connect usb directly to VMware.
I ended up creating a virtualbox VM this morning, and it includes native USB passthrough, which allowed me to use the USB adapter to connect to the processor.
Hello friends The IT department is pushing me to use Hyper-V on Windows 10. Have you use it? Is it a good option? Thanks in advance.
4,251
Trying to test a Channel 0 ASCII to Hyper Terminal using 1747-L532 Channel 0 is set to user Do I use a Straight through cable or Null Modem from...
1,567
Anyone ever set up Archestra in a Hyper V configuration in windows 2008 R2 Need some help Thanks
1,460
Our IT department is sold on Hyper-V for virtualization due to the savings in windows licensing. I have not gotten into VMs yet, but my...
2,041
I am looking for a replacement for hyperterminal. My XP system doesn't have hyperterminal or telnet. I am currently trying to use PuTTY but it...
19,034
