I feel slightly stupid right now (Step 7, S7-300 processor).
Tharon
Jan 2007
Other
1,430
So, I was reworking a machine that was inherited. Very little documentation and absolutely no comments in the program (just uploaded, without a copy), and it used Step 7, which I had very little knowledge about.
I dissected the program, found out what it was doing, and re-wrote and added to it, filling in the comments and symbols. Once finished, I was very happy with the way the program looked.
I go out to the machine and try to download the program and I cannot. Turns out my addresses were to high (I used some M300+ addresses). Apparently I can only use up to 256? I wish it had told me this before when I was saving my work. I guess it only checks syntax, and not whether or not the addresses are even possible for the chosen processor.
So here I am, lesson learned, re-writing my program. Cursing Step 7 under my breath for not warning me in advance while knowing it's really my fault for not having proper training.
Did you use symbols for the M addresses ? If so generate source code for all your blocks (using symbolic representation), change the M addresses in the symbol table then re-compile. No re-writing required.
Ah. Here I already changed the symbol table to represent the new addresses. It's not that much I have to change luckily, just a handful of M addresses sprinkled throughout the program, luckily most of the long stuff I wrote was still in the correct range.
I'll keep that on record though for future reference.
FYI, I have a BSL that may need to shift its Source's bits on contiguous scan cycles; a single BSL will not do that because it only executes a...
1,935
Hey all, I've recently been asked to help spec some SCADAPack controllers for a project. I'm specifically being asked if the E series...
8,078
Well I've been programming different things for the past few years but today I remoted into a client's site to adjust some logic I put in for them...
2,243
I made an application in flex Runtime for entering batches. Can be stored in csv and transfered to the machine. But, when entering data in an...
1,759
in my experience, they dont work well in my field, which is oil and gas production. ive worked with rosemount apex, rosemount 3300, k-tec...
3,949
