I fix Version 3 modbus ethernet connection
shandra_ck
Jan 2005
Malaysia
63
Hi all,
I need some idea to change the communication between I fix 3.0 and PLC Siemens S7 200 from serial to ethernet.
Current connection details:
Software: I fix Version 3.0
Driver : Modbus Version 6.10e (MB1)
Communication : Serial
What should I do if I need to change the setting to ethernet?
I found out that, I need to install another driver called MBE (for ethernet), recreate all the tags and assignment to I/O, add a CP card to S7200 (checking on Siemens CP243-1).
Do give me your feedback on above connection or any other suggestion?
Does siemens CP card support modbus ethernet connection?
Can anyone send me the driver software for MBE?
Thank you.
Regards,
Shandra
I fix 3.0 and drivers
Thanks for the driver.
I would like to get more clarification on the connection method.
Can I use more that one driver in IFix version 3.0 at the same time? Currenlty its connected to Modicon Modbus Version 6.10E, and I need to add another driver to connect to Siemens CP231-1? What driver do I need to use. (This connection is for the ethernet)
If anyone familiar with the connection please do let me know.
Thank
Shandra
Hello All, Can anyone assist me with GE proficy ifix trial version for tutorial practice as i am new to this. Thanks,
1,717
Hello, I are trying to setup an old Intellution IFIX version 2.5 system (with 2 HMI PCs). I currently have only one IFIX developer software key...
2,668
Very often I have to reverse engineer something from an iFix parameter inside an array to a bit in iFix. It's a pain to do as I've yet to really...
1,910
Hello, I am doing a project in which a system was designed with an older version of Ifix and the backupfiles are being moved to version 5.8 for a...
3,400
Is there any tool that can be used to convert multiple TGD tag group files at once, into CSV? I have a whole bunch of TGDs to edit and it is...
2,345
