I need help understanding factorytalk studio macros
stu
Aug 2005
England
786
Hi I was trying to use a plc input to login into the engineering screen rather then a password , and came axross the login /log out macros can you help me to to use macros please thanks stu
I'm what sense? The input in the PLC goes true & it allows access to the engineering pages?
Or input goes true log into engineers account?
Take a look at triggering a macro from an event. Your event is the Plc input & use the macro to log into the engineers account. I can't remember the syntax but I answered a post on here about log out macro
Ash
Hi ash yeah when the input is true login to engeering account , plus I am willing to learn as much as I can about macros and setting them up as I've never done before . Thanks stu
OK, i thought of two ideas for you:
1. Visibility
If the input is true allow the engineering button to be visible, if not then hide it. Really simple & crude but could do the job.
2. Using a user account
Heres the post about using a macro to log a user in:
http://www.plctalk.net/qanda/showthread.php?t=102907
Now to trigger it, when your engineering input is true. Once you have created an macro to log into the account set up an event.
Action = The macro to log in
Description = your description
Expression = Engineering input =1
Simples... But remember to log the engineer out once they leave the page or the input is false
Id probably go with the user account one.
Ash
Edit: Presumed your using SE, cant quite remember if these functions are in ME or not. I can take a look later if you let us know which your using
Hi ash
Yeah I thought about using visibility as a easy fix then saw the macros and wanted to learn and try but didn't know how to use lol, sorry guys I forgot to say I'm using Me thought they may be the same ? I will try this out thanks guys
So on the macro set up
Trigger = input address
Expression = if Trigger input =1 then login "username" "password"
Else trigger =0
Is that right ?
Very new to macros guys
I appreciate your time thanks stu
Ok then, my apologies. I was basing it on SE, i have just opened ME & the macros work differently.
As far as i am aware i don't think you can log in using an input, i just had a play around and you can either use the visibility of a button to access the page or use the global connections to open the screen when the input is true.
Sorry once again,
Ash
Ok ash thanks for your help , i have just done it as a visual on the buttons which works fine , I'm sure you will get me out of trouble another time ha ha , thanks again stu
https://imgur.com/a/kKPtzyP We are making improvements to these motor controls by replacing these old resistor banks and DC generator with DC...
1,804
I get so confused by Rockwell's licensing structure. I have two PC's that will be running the same SE application. Can/should I run this as...
1,865
Good Afternoon , I'm sorry. But I'm struggling to understand this combination of integers in this MOV , and really anywhere else this scheme...
1,623
Hi folks, I am wondering if you guys can help me understand what the intended operation was for some logic that relates to the operation of the...
1,652
Good afternoon, I want to understand this old piece of logic I found in an old program (RS Logix 500 on SLC 5/03). I have two rungs here in a...
3,692
