I need some help with GE versamax PROGRAMMING
kboggs
Oct 2004
Spiveys corner, NC
47
I that have a simple program and GE will not give too much info. all I need is to have a pushbutton open a door and start a timer and drop out after 6 sec. the program that I have wrote has some flaws and I would like to have someone look at this and help me correct the flaws. I will only send 2 rungs of the 64 and thanks to
everyone
Trouble With Ge Versamax
everyone
You don't need to enter the END statement. It's built-in.
There is an END statement that you can program, but it is intended for debugging purposes. You insert can it into a program to see if your logic works correctly up to that rung in the program. If it works, you move the END statement to allow more rungs to be executed and try agin. Lather, rinse, repeat...
42
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
345
171
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
74
