I need to monitor over the internet some VFD
josfal
May 2018
San Jose
Hello Guys,
I hope you can help me with this. I have 6 Weg VFD, CFW-11. is there a way of monitoring it from the Internet? If not is there a way on the plant to monitor it from a computer?
I also have the same question for an Allen Bradley, Powerflex 525.
Thanks in advance for the help.
You need to monitor with a HMI o Scada (for example show a motor running, amps, speed) in the computer or just use a software to program an monitor remotely the VDF?
Are you using PLC to command the VDF?
We are not using PLC's... I need to know if there is any software that tells me if they are running and the running speed in Hz if its possible. I am having an issue in the company where i am working at, the electricity is very bad, so the generator has to come on at least 3-5 times every day.... sometimes the VFD don't get back to the speed they were set up before the power outage, that's the reason why I want to monitor them remotly, so I dont have to walk thru the plant checking if they are working or not.... Is that possible
For me the way to go for secure data communication over the WAN is OPC UA ... install an OPC UA server in the plant and configure it to accept only connections with trusted certificates.
So Mil-Ram gas detection closed down, and now we need to find another gas detection maker to hook up to our SCADA. Just wondering if anyone here...
2,694
Hi all, I want configure Profibus-DP nodes of Bubenzer CMB2-SB brakes which monitors the brake status and sends signal to PLC(profibus...
2,108
has any body used the 809s-e2 Current Monitor from ab and if so how do i program it. i have one and would like to try to use it. i have looked for...
1,585
Useing the LogixPro Simulator, can anyone tell me how to write a ladder logic program for an alarm monitor circuit. In the circuit i must have a...
1,425
I’m working on two “Energy Consumption” projects for two different customers with two different PLC; AB1500 and AD260, the two most popular PLC in...
1,967
