I/O Device manager
Thersonder
Jun 2014
Cape Town
Hi Guys,
I have recently been tasked with updating my company's VM Block (output handler) for siemens s7 300/400 plcs (we use indirect addressing in it). o_O
It currently has the normal bells/whistles: activations, running hours, automatic mode / manual mode, on delay, off delay. Feedback errors and travel time.
However it is designed specifically to do single acting outputs and not motorised valves or 5/3way or 5/2 way non returned valves. It also has no time and date functions or logging of activations or time to maintainance timers.
What I would like to hear from other experts is what functions / features they would like to see/ add in if it was up to them and secondly what the structure would be.
I was thinking a FC that linked to a DB with a UDT so that I can extend the length based on the number of devices and an identifying int to specify which part of the code should be run (motor/ valve / motorised valve etc). As opposed to 4 seperate FCs which are called per device with an identifying device number that then points to that specific device's memory range in a udt structured DB.
Any thoughts or opinions are welcome.
Geoffers
Hey guys, Setting up my new laptop on windows 11. Got all my software working in Ethernet/IP. Now i'm trying to connect into older PLC running...
1,367
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
78
Anyone have a idea of what would cause a failure of all nodes (buckets) of an AB Device Net MCC upon a power cycle of the main feeder for that MCC?
547
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
80
Hey guys, I have to take an upload of a program on an S71200 PLC to change a hardware config option and then redownload the program with this...
129
