I/O for Red Lion G3
kolyur
Oct 2004
Wooster, Ohio
1,602
Can anyone with G3 experience suggest an inexpensive way to put some I/O on a G3? Basically I just need to control about 10in/10out, and all the logic would be done in the HMI. I was thinking about just connecting a small brick PLC via serial or Ethernet and controlling the I/O directly from the G3 (PLC program would be blank). But is there an easier way? Perhaps some field I/O that Red Lion has drivers for?
I know that TURCK offers the BL20 products which work great for I/O to the G3. Connect over ModbusTCP. But this option might be a bit spendy for only 20 I/O points.
Joe_WaZoo
Thanks everyone for your suggestions.
Jezz, I checked out your link and then found the 4000 series which are RS485 serial and less expensive, and the Red Lion has drivers for them. I think I'll go this route as my I/O requirements are very low.
I forgot about them, we have only used the ethernet units as we allready have the network in place.
But they do get eaten by Eagles.
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
268
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
279
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
108
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
221
I'm trying to use a Red Lion Cub counter (Cub5B00) as a counter and give the cub's counts to a Graphite G12 PLC/HMI to display. After about an...
114
