I see it on RS linx who, but can't upload it
hurricane
Oct 2005
North Carolina
I have a panelview 550 connected to a slc 5/03.When I do a who active I see it showing up.THe problem is when I got to panelbuilder 32 I can't upload file from 550.
I had it once,
Check your PB version it might be old.
try directly to the panel not thru network.
Try to use compak flash.
One of this ways has to work.
Firmware Version.
I had this problem one time also. It turned out to be a firmware issue. In Panel Builder you have to select the correct version for you 550. If they are not the same I do not think it will connect and let you upload, but will show up on RsWho.
Also if you connect dirrectly to the 550 depending on how you connect (such as sitting on your desk powered up) you may needed an external power supply to alow you to upload. The 550 does not have a internal power source for communication (at least the ones we have do not. We had to buy the external power source). You do not need this if you leave it in the network (with a plc) and connect directly to it.
I am trying to upload a file from a panelview 600 and all it has are serial ports. I finally got the thing to communicate and in the process of...
2,065
Can RSLinx upload and download ladder programs from/to ControlLogix witout RSLogix? I need to develop the application software to upload and...
5,823
I'm thinking I need a newer version of software. I have 2.10.12. I have a SLC 5/05 ethernet processor. I don't have the original program, so I'm...
5,739
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
67
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
223
