ID this ultrasonic sensor
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,794
Looking at a sensor wired directly to a PLC analog input (DL450) and trying to identify a make and model.
Sensor is working, but if I sign a calibration sheet, probably ought to have some sort of detail to go along with it.
There is no label on the sensor and I haven't tracked down the PLC math just yet. I thought I would tap into the vast knowledgebase that IS PLCTalk to beg for WAGs.
It is probably not a Milltronics/Siemens ultrasonic.
The Milltronics/Siemens Echomax transducers are connected to a proprietary remote electronics box which interprets the echo signal and creates a signal conditioned 4-20mA output. The transducer is not a level transmitter; the transducer's output is an unuseable, low level signal.
Reportedly (see post #1), the wiring goes direct to a PLC analog input which infers that the level signal is an industrial, high level signal like 0-5V or 4-20mA.
Siemens has had a couple of 2 wire, loop powered level transmitters - Probe, LU-150, Probe LU, LU-180 - but none of them looks anything like the photograph (they all have 2" NPTM process connection threads).
I did not find any remote transmitter, and I didn't finish tracing out the Directsoft logic. The value that shows up on the HMI comes from a V memory register that is only referenced once by some totalizer logic. I have a feeling that the value is calculated by a proprietary ICI control board mounted on the door of the panel. I always have to dig deep in the manuals to figure out where analogs end up in a Directlogic PLC so I will try to do that tomorrow in the office.
I verified the reported value is accurate at two different levels, but I would sure feel better about it if I could fill in more of the missing details about how it gets from that sensor to the screen.
Every flume I have worked on that uses an ultrasonic, has the flume math embedded in the transmitter/display, although I suppose it is possible that even an old one might have the smarts on-board.
There was one condulet (not shown) at the end of that flex conduit that I opened up and inside is a nicely spliced cable with heat shrink. The PLC cabinet is about 75' away and has two 8 channel analog input cards, no drawings, all the cables look the same, very few labels...
Looks like a Greyline ( an older version).
https://pulsarmeasurement.com/dbi-modbus.
Completely self contained.
Interesting.
The main PLC is connected to a radio network as a Modbus slave on one of its serial ports as well as a proprietary single board computer on another serial port.
Thanks for the tip. I will contact them and see if they can ID it from that picture and perhaps send me some literature.
Hi, I want to use an ultrasonic sensor with Micro850 PLC. Is there any cheap sensors that I can use for distance measurement?
2,211
Hello In my factory we use ultrasonic level sensor VEGASM61 to measure solar fuel in a tank. I contact with many suppliers to buy one. many of...
2,346
Hello everyone, I have a pretty basic question which I can't seem to find any information for. I have an ultrasonic sensor connected to my analog...
3,468
Dear, Consultant wants to use a bubbler system for storm water pumping stations, pumping stations is 800 liter/Sec. What is the benefit of...
4,548
I am using an ultrasonic sensor to measure distance and the input is not too stable. I know this is the nature of the sensor,ambient conditions...
4,156
