IEC or UL standard for extra discrete I/O
Unregistered
Guest
U
Hello all,
I've seen many opinions and guesses on how much expansion there should be in regards to discrete I/O in a panel or subpanel. Is there an IEC standard that spells this out for extra discrete I/O?
Hello, I have a small programming task that I need help solving. I have to: * Create an analog input (4-20v)and a digital output * The analog...
45
25,210
One of my fellows encountered a panel in which IEC 81346 standard was used for component naming. The customer has problems when they want to...
2,492
Kindly, what is the equivalent of Class J fuse in IEC standard? Like what is the replacement of the below fuses in Siemens (or other) brand...
2,225
i am supposed to write a PLC program using the IEC 1131-3 standard. if i write it using the mitsubishi GX IEC developer will i be able to use the...
9,718
Dear Friends There is a GE Fanuc PLC software called Versapro for programming the plc.This software is configured on the PC.In versapro I have...
11,426
