Ifix 3.5 connection to PLC
NR16
Sep 2013
Port Louis
I have restore a PC with IFIX 3.5 and installed GE9 driver.
I have 4 PLC's and ping to the PLC is ok. The IFIX 3.5 is not communicating to the PLC's.
Is there any configuration that is required to set up the communication.
Any advise would be much appreciated.
Thanks in advance.
The answer to your question is 'maybe'.
To which PLCs with what port and protocol(s)?
PLC's & Connection
The PLC's are GE Fanuc 90-30 using Ethernet port on the CPU and remote PC using lease line connected on the COMM card using ethernet.
PLC's & Connection
Hi RussB
The PLC's are GE Fanuc 90-30 using Ethernet port on the CPU and remote PlC using lease line connected on the COMM card using ethernet.
I hope you could help me out.
If you are using the SRTP protocol the only thing you will need to do on the Ethernet connections is to get the IP, Masks, and Gateways correct. I have no clue on the "Leased line" as to what it will take to get through.
You do know that iFix is currently at IIRC version 5.8 and the GE9 driver is also very old.
Hi RussB
I had already set the IP, submask gateway.But not good.
Is there a way to test the PLC connection from IFIX. I read about GE9 power tools, is it possible.
I have installed the IFIX 3.5 on Win XP and the old PC was loaded with GE9 driver.
Sorry, I'm not familiar with the IFIX.
'IGS.B88_QC.B88_QC.Global.U_7087X001PDS101.STS.CMF' so in this display I have links like this, now I have seen direct opc to plc before but I...
1,990
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
151
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
159
Hi everyone. I'm beginner with Ifix. I'm appreciate if you share me some document to understand how to play with Ifix 6.0. By the way, I have some...
713
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
443
