iFix 5.9 Animation with Multiple Conditions
Dood
Feb 2018
New Orleans
I'm a bit new to iFix and come from a FactoryTalk SE background. I'm looking to make a rectangle flash if any of 5 digital alarms goes into an alarm state. In FTSE it would be a very easy IF X OR Y OR Z, THEN Blink etc. But it seems in iFix I can only include one tag on the data source.
I know I could stack a bunch of rectangles, each tied to one alarm - but I'd prefer not to.
Anyone know of a good way to accomplish this?
Thanks!
Ok scratch that, you can INDEED just stick an "OR" statement right there in the data source. Just took a few times to find the right syntax.
Yea, iFix is finicky about spaces and parens too. Also note that if you use raw formatting on a datalink, format it how you like, then copy that datalink and change the tagname, the raw formatting goes away.
That is unless you right click it and use the advanced animations to change it, then it doesnt. iFix is full of that kind of inconsistent ****.
The VB script is faster than the database response too so if you write then read you will likely not get what you just wrote. I could go on and on...
Is there a way copy an object's animation settings to another object? This is a very simple task in InTouch but I cannot find a way to perform...
3,162
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
150
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
157
Hi everyone. I'm beginner with Ifix. I'm appreciate if you share me some document to understand how to play with Ifix 6.0. By the way, I have some...
713
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
442
