ifix 5.9 constant beeping
eervin84
Aug 2019
Illinois
I am trying to figure out why ifix is constantly beeping every second. I have tested to be sure that it is ifix as the beeping goes away when the program is closed. I initially thought it was the alarm horn but disabled/silenced that and acknowledged all alarms to no avail. I cannot seem to find the source of this sound in the software. Please help.
So far what I have found is that if I disable the SAC task in windows task manager, the beeping stops. However, this also breaks all of the alarm functionality within ifix. I also tried using the command line parameter for this task to suppress notifications for no data and communication alarms with no success. Thoughts?
I have that exact same problem on iFix 5.5. However, I do have plenty of alarms that are going to alarm areas that no one looks at. Perhaps you have something like this?
I suppose that is possible but I would expect that disabling and/or silencing the alarm horn would stop this issue, if it were truly caused by an alarm. It does a slow steady beep pattern for a new active unacknowledged alarm that is an entirely different tone. This stops after acknowledging the alarm but this soft one beep per second tone persists. I have isolated it to the SAC task of iFix as mentioned earlier but not sure where to proceed from here.
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
148
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
156
Hi everyone. I'm beginner with Ifix. I'm appreciate if you share me some document to understand how to play with Ifix 6.0. By the way, I have some...
709
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
441
Hi team! I'm starting some iFIX application migrations and some of them are being developed with the high performance library. Some objects that...
814
