IFix invert property
robertmee
Feb 2008
NC
2,022
Converting an iFix 5.0 HMI to Ignition, not developed by me. Been a long time since using iFix. On Digital Input tags, what does the property "Invert Output" on the Advanced tab do? Does it take a PLC value and invert its state in iFix? Such that PLC tag =0 then iFix tag =1. This was done on a number of tags that appear to be alarms only. Why wouldn't the previous developer have just inverted the Alarm Type property? Is there some advantage to using Invert Output? TIA.
Thanks for the link...I had read that description in another format, and the fact they call it OUTPUT invert is confusing on how it applies to DIs.
I don't have iFix to test now (good riddance), but I think that option needs to be read along with the "enable output" option.
The enable output, as far as I remember allows you to write to the iFix tag and it will then write over to the PLC tag (don't ask me why, I don't know) that is used to read the signal.
The tag itself in iFix wouldn't be inverted, it would match whatever value the PLC had.
I don't quite see how useful this can be in any application, but I'm sure someone else will chip in.
To invert the tag's value from the PLC value, I think you'd need to use signal conditioning, though I'm not sure it works on booleans.
By the way, good on your customer to get rid of iFix.
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
154
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
161
Hi everyone. I'm beginner with Ifix. I'm appreciate if you share me some document to understand how to play with Ifix 6.0. By the way, I have some...
716
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
445
Hi team! I'm starting some iFIX application migrations and some of them are being developed with the high performance library. Some objects that...
819
