Ignition help?
bitmonkey
Oct 2015
Ohio
94
Hi Guys,
So we've got Ignition running on a server and we're using it as a maintenance call system. And there is a simple table that displays a time stamp of when each line called for maintenance, when maintenance arrived, and when maintenance was completed. Suddenly the log table stopped updating. So when I got to the Status tab on Ignition and look at Store & Forward I see the local cache is full, but I don't know how to fix it. This OPC/SQL/HMI/SCADA stuff is all Greek to me. Is there an easy way to fix this?
Thanks guys for trying to help. I agree that it's going to take someone more familiar with it than me to fix the problem. But just to answer your question, The database is connected, but one of my OPC is not. I have no idea where any of these modules reside. They're just going to have to wait for our IT guy to come back from vacay, or call the guy in who set this up. I just thought maybe there would be a simple way to "reset" it and get it going again.
Go to configure/OPC connections/servers/ click more on the OPC that is faulted and select "discover endpoint" this will show you IP or hostname of PC it is running on. This is for 7.9 so menu may differ slightly
Hi All, Has anyone of you dealt with the easy chart or any other graph or data trend viewing options? I want to filter the input data I want to...
4,983
Hello all, I'm making templates in Ignition and needed help with the scripting. Pretty basic-On a motor's template, I want it to have three...
2,804
Ok so i have jumped right into Ignition (v7.8). I Have the basics figured out. The videos help lots. I have setup an alarm in ignition. I need to...
4,904
Could somebody please point me in the right direction? I'm trying to incorporate a table into each motor's faceplate. It's a simple, two...
3,218
hi all i'm new in ignition SCADA and i want to try it using trial version i want to try it with M340 plc i create the device and now i want...
3,468
