Im having problems with a program pt 1.
arosenbach
Oct 2003
im working on a program where a process mixes a material durring the night when the facility is not in production. the material for the next day has to mix a minimum of 12 hrs mix speed must be controlled or the mixture wont set up correctly for the next day. i have to use a DC motor to rotate the magnet past a proximityu sensor. voltage from a seperate power supply can control the motor speed. while the ladder cannot easily control the motor speed, the on off of the motor must be controlled by the brogram through the SLC. the photo sensor should control the power to the motor, due to the darkness when the facility shuts down. speed should be continuously monitored and if it gets to slow or to fast an alarm should go off. speed should be kept between 200 and 500 rpm's and we have to use the 4-20mA to send the speed out to the digital panel meter. a start/stop rung should be included such that the operation can be stopped and restarted.
If you search past posts you will see that nobody gets a question like this answered here. You need to be specific about where you are having the problem. Post the logic you have so far, blah, blah, blah.
Ok. If I understand you correctly you are trying to control the speed of the DC mixing motor. Is that correct?
Assuming it is, you have a prox sensor that should be monitoring the rotation of said motor. From what you see by that prox, you are determining the speed of the motor and then displaying it on a panel meter. While you have indicated that the speed of the motor needs to be maintained, you have not indicated what control technique you are using.
So what are you having problems with? Any logic you have already worked out would help greatly.
Steve
Me thinks something be fishy here!
To do what exactly? Rotating a magnet past a proximity sensor hardly seems worth the effort.
Are you sure? Sounds kind of like a DC drive but not quite.
By this I assume you mean that the SLC is not capable of controlling the motor speed? That may or may not be true depending on your skill as a programmer and the I/O that you have. Surely the SLC can turn the motor off and on. But so can a switch.
Kind of like the streetlights in your neighborhood?
Ya know, this whole thing is beginning to sound like an assignment from a student work book. Good thing there is no tight speed control requirement.
You think?
I am in agreement with Vetteboy and Steve, you have to do some work here and post something that you may need help with. Otherwise, ask your instructor or other students in your class what they think.
11 months ago I ordered a 10" Redlion HMI. I was given an April delivery date. April came and went. I waited, and in June I asked our vendor...
2,370
and apparently my r and 0 keys. altivar 320. Calculated stop works near perfect for the ATV 312. ATV 320 not so much...
1,045
Good Morning , I'm trying to move a total for a dose into a dose history. I'm able to get my totals to move just fine. I would also like to...
2,407
Hi everyone, could really use some help if you get the chance!! Trying to create discrete I/O tag with an micrologix program. Green light on...
1,529
We had to replace a bad Panelview plus 6. It was running factorytalk v5 and kepware v4. This unit is talking to two AB PLC 5s over DH+ and 3 TI...
1,827
