In Logix5000, can we consume and produce the tags between two controllers which are….
wendaiyu
Jun 2014
toronto
87
Hi, guys!
In Logix5000, can we consume and produce the tags between two controllers which are Not in the same rack, but are both working under our factory network, such as IP 10.10.28.101 and IP 10.10.28.201?
Thanks a lot.
Of course, but when you say "our factory network" you scare me. Control traffic shouldn't be on the same network as the secretarial pool watching cat videos.
LOL, Thanks a lot, buddy.
Could you tell me more details about how to do it? I cannot figure it out.
Thanks again.
First things first, carefully define the data you want to produce/consume. P/C tags can't be edited without a download, so know what you want before declaring the tags. Add the respective other Ethernet card and controller to each controllers controller organizer. Then declare the tags. If you're going to use UDT's they will have to be defined in each controller as well.
And the producing processor will need to be defined in the I/O tree of the consumer.
The "Logix 5000 Controllers Produced and Consumed Tags" programming manual will be helpful in this effort.
Hi all, Hopefully this is a somewhat quick question: A few of the loops in my system have physical I/O at two different PLCs. My water filter...
2,832
A puzzler... Scenario - 1 "Master" ControlLogix L73, and 7 "Slave" ControlLogix L61 - all Version 19. All chassis interconnected via a "Ring"...
8,396
Hello everyone, Wondering if anybody can help me with this: I have a CompactLogix processor running a little robot cell. Every 200 cycles...
188
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
181
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
490
