Inclinometer Voltage to Degree Angle
jareds2020
Oct 2019
USA
Hi All,
I am currently working with an Inclinometer that ranges for 0-360 angle degrees single axis (0.1-4.9 Volts).
Is there a conversion equation to go from the voltage output by the sensor to a angle degrees?
I am trying to display the angle for reference but am currently stuck on a voltage display.
Thank you in advance.
A standard formula to scale a value is:
Code:
Scaling uses this formula:
Ov = [(Osh – Osl) * (Iv - Isl) / (Ish  – Isl)] + Osl
Ov = scaled output value
Iv = analog #Input  value
Osh = high limit OF the scale FOR the scaled #Output value
Osl = low limit OF the scale FOR the scaled #Output value
Ish = high  limit OF the scale FOR the analog #Input value
Isl = low limit OF the  scale FOR the analog #Input value
But it depends on whether you are using Real/Floating Point values or Integers. You may have a scaling function built in to your PLC.
OT - I have an application using an inclinometer to help position the angle of a die head for extruding adhesive in a coating process. The current...
1,073
Hello All, I am fairly new to PLC's outside of the class, so apologies for any newbie communications. I am trying to set up a system that will...
1,412
sorry about the fuzzy picture. I am studying about this inclinometer pinout. The gray wire is for "teach." So, applying 5V signal to the teach...
2,113
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
138
I've got 6 identical regenerative vacuum blowers powered by 6 identical drives in 3 identical panels all fed from the same 1 main building feed...
27
884
