Indirect addressing in Unity pro
Mar 2010
Cape town
Hi
I want to do map the bits from a range of %KW to a %QW
for instance
Var_pointer := %MW0
%KW(Var_pointer) := %QW0;
Lets say the value %MW0 is 50
i want to map the bits inside %KW50 to my output word
I used structured text to illustrate what i wanted to do but any form is acceptable.
o_O
Please Help
Simplest way is to create a tag (eg Test) and set its type as an array of %KW and then use Test(%MW) to access the value
You will need to set the project properties to allow directly accessing array variables
Hi thanks for getting back to me
This is what i did in the meantime
%MW0:=%KW0[%mw10];
If %MW10 has a value of 123 this will move The value that's inside %KW123 into %MW10
This is basically what i tried to do
If there is a better way i am very open to new Ideas otherwise thanks so much for the help
Now i am struggling to write/Map %MW0 to (for example) %QW0
but looks like i am using the wrong syntax to specify the specific output word
Not so clued up with Unity yet :ROFLMAO:
Depends on what plc you are using.
For example m340 = %qw0.1.0
first 0= rack number
2nd 0 = slot on rack
3rd 0 = output/input number on card
I have to check 1024 (sequential) bits for change of state in any of the bits and record which bit changed. I was going to do something like...
4,485
Howdy folks, I am an Allen Bradley guy currently living in an Emerson world. Working with Rx3i on PacSystems Machine Edition v. 9.6? i think...
624
Hello, I'm very new to programming with absolutely zero schooling in this field and pretty hands off training in my new role, it's been fun...
670
Hello Friends, I am trying to index M Bits, however GX Works2 is not allowing it with following message. https://ibb.co/zPcqj6M...
1,387
Hi All, which the best way to do the indirect addressing in an optimize DB? Ccurrently this is my partial code inside an FB...
2,278
