industrial computer fault
johneedw
Oct 2009
asia
204
Hello friends,
I've industrial computer controlling a blister machine.
Now i'm facing a critical fault with this computer, when start it, bios complete memory test the stop ! no other checking and no boot !..
the mother board model is PCI-12S VER:E1.
The attachment showing the details of this computer..
Help me please to determine the fault and to help this computer to boot..
thank you
Press DEL to enter SETUP and look if the board recognizes the Hard Drive, may it is dead or 12V supply is down.
As Ife said, the hard drive is not recognised, enter the bios and check the default parameters then
check if all connectors are secure if not ,
change the power supply and or the hard drive.
And I thought I ran some old stuff . . .
You do have a copy of the contents of the hard drive do you not?
As suggested, check the power supply volts. (You may need to research the internet to see what volts go on which pin of the connector.)
Check the BIOS settings - most of the time using the default settings works. But I had at least one system back in the day where if one of the settings wasn't set to something 'strange' the system did not work.
I would try replacing the CMOS battery. If you have a second such computer, still running, write out the BIOS settings.
That looks like an IDE hard drive . . . If the system is toooo old it might not work with todays larger IDE drives - and with everything going to SATA drives . . . E-Bay might be able to help you acquire old small drives. (On a really old computer it was necessary to punch in the values off the drive into BIOS. . . more recent 'auto-detects' the drive. Don't know which you have.)
Good Luck.
Poet.
Thank you friends,
I'm really found that the cmos battery is dead! but i don't know how to replace it !..
Please, see the two images below and advice me how to replace the built-in battry ?!.. Can I replacing it without soldering ?!..
That does not look like any CMOS battery I am familiar with.
Usually they have numbers on them. Is there any chance that
is a cap of some sort over top of the battery? Most of the time
in a PC compatible the battery looks a lot like a large stainless
steel button. With numbers on it. '2032' are common numbers.
Poet.
Hello friends, I'm facing a fault in ASEM industrial computer. The 20GB IDE hard disk has damaged , then I've replaced it with 40GB new one but...
2,335
Hello gentlemen, I have a quite complex piece of equipment that I'm slowly getting to know and I have yet to find out what PLC or "Computer" runs...
2,046
Hi, guys, how’s going? We get one SIMOTION D435 machine. The communication between D435, PLC and HMI is built by Ethernet cable. (D435 IP...
4,924
Hello friends, I'm facing a failure with an industrial computer used for ultra sound medical detection device model (IVIS30) from Chison company...
20
5,091
I have a Allen Bradly 750R computer, with Windows Server 2003 R2 OS. It has 2 hard disks with RAID1 configuration. There is only 1 partition...
2,129
