Inflight grain measurement
Alan Case
Apr 2002
Wagga Wagga
1,268
Has anyone ever come across a setup to measure the weight of grain as it is falling from an auger into a truck.
Regards Alan Case
Hi Alan,
Sorry, can't say I've ever done anything like that before. I asssume you want to control the amount of grain that is "dumped" into the truck based on weight?? What about having the truck sit on load cell and control the auger's movement based on the weight deposited in the truck??
Just my $0.02 for whats it's worth.
Andrew Evenson
we have a noncontact density meter for clinker.
Uses radioactive isotope cesium something.
Might work on lower density materials, you would have to allow for the speed it was falling at, should be fairly constant?
look here for details.
Grain Flow measurement
There are M/C (made in Italy and Japan(Toshiba i am not so sure at this time) that measure the flow of Grains, from there you can integrate to get the Mass or weight. I do not have the name of that M/C but could post it next time i am here.
I am not sure if that would help.
Or are you truing to get the compensation for infilght material to give a better stop command ?
Arc
Combines do that nowadays. Maybe you could call up your local John Deere dealer and find out how they do it.
There used to be a company called (I think) Triboflow in the states that had sensors for measuring particle flow in pneumatic conveying systems. You could try to find them, or you could contact a local pneumatic conveying system supplier and see what they have. Airzen, Roots, and Gardner Denver are suppliers of these kinds of systems that I think are available in Australia.
It sound like you need a weight feed system.
http://pia.khe.siemens.com/index.asp?Nr=9892
Usually this is done with load cells supporting the auger or from a belt scale. The system takes weight and conveyor speed as inputs to calculate a mass flow rate. The auger could be interesting to get a speed of the screw but I am sure it has been done.
I have used Mettler Toledo and the Siemens/Milltronics systems successfully.
Best of luck.
Hi guys, :argue: I dont have very much knowledge on the hardware available for automation processes. The question : is there such a sensor that...
5,590
Hello, friends my 1756-if16 differential connection, has been used again (almost 10 years), the measurement value of each channel of the entire...
976
Hi I have an application where i need ambient light sensor. While I can use sensors like BH1750. I am not sure how i can use it in an industrial...
635
Hi All, I am using CompactLogix L33ER with a 1769-IQ16F card for a rotating machine shaft ( drive and driven pulley arrangement with V belts )...
2,013
Evening All, Hoping for some advice & any suggestions on a tank control system that we will be looking to optimise soon. We have a tank that we...
25
4,286
