input edge
dwpang
Aug 2012
singapore
68
hi anyone can help to explain the meaning of input edge? or how does the input edge occur? the attach pic explains more. thanks.
I think 'input transition' would make a better choice of words here than 'input edge'. A transition, change of state from something to something else.
ok.. i still dont quite get it. so as seen from the attached pic, %sw58 occurs when blackout happens right, and the reason is because of this input edge or input transition. so any examples of what can cause this to happen? thanks.
I just had a look through the manual (LINK), and on page 463, there is a setting to use a run/stop input.
Maybe your PLC is set up to use an external run/stop command (relay, switch, etc.)?
If it is, then I'm thinking when that input turns off, it will stick a "1" in %SW58.
Some PLCs (DL405 for example) have a connection for an external 'run' contact. This may be something like that.
-Eric
Hi guys I would like to ask under twidosuite blackout there are 5 reasons listed for the system word %sw59 right. Namely input edge, software...
1,149
Hello All, After trying to transfer some field changes on the safety scanner microscan3, and verifying, the device is stuck at .... waiting for...
61
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
89
Hello, I'm looking for a dirt cheap digital display + input, that would be wired to an analog input and analog output. This would be for my home...
266
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
91
