Input fields are cross hatched
gusterminator
Feb 2009
Thunder Bay
85
I recently did a clean install on Factory Talk View SE client. Version 7 with 40 patch up dates. I have everything working properly except for the input fields. The area to type in the speed change is cross hatched out. I did have a VB error alarm at the bottom of the screen, I'm not sure if this is related or not. Does any body have any ideas on where I should start to solve this issue.
Gus
This worked for me
1. Ctrl-Alt-Delete and select Task Manager
2. Under Processes tab, select RSLinksNG.exe and end this process.
3. You may need to select the show processes from all users check box at the bottom left of the Task Manager Process Screen.
PS it may take a couple minutes.
I tried ended the process RSLinksNG and nothing changed. I noticed an alarm that popes up when I open up the screen with the input in it.
cause: Microsoft Forms 2.0 Text Box: Newer File version of Active X Control required.
cause : Microsoft Forms 2.0 Text Box: CAB file missing on the server: http://hmi1/RSviewActiveXControlsetup/FM20DLL.CAB.
By reading this I would think I have a file on the computer the HMI is installed on that has an old version of forms 2.0........or maybe a newer version than the server. All other HMI's are working fine and I copied there HMI file over to the computer that isn't working so the actual FTView File is the same on all computers.
Any idea's
Thanks.
So your input field isn't a FTView SE Input Field, its a Microsoft Forms Text Box. Yes you've run into an old issue. That's why I avoid using ActiveX objects in FTView. Many Microsoft products upgrade the FM20.dll, such as Microsoft Office. You either have to upgrade the Forms .dll or edit the screen on a computer with the correct version.
Thanks for the help, what I ended up having to do is search the computer for the FM20.dll file and delete it from the directory. Then I did a search on one of the computers that was working. I copied the file over from the working computer to the directory of the non working computer.
Cheers
Gus
Hi I have tried google my problem but without any good result. I have a display with a lot of input-fields that are connected to memorytags. I...
1,505
I'm new to using FT View SE and trying to figure out if there is a way to remove the frame around string or numeric inputfields. I cannot find any...
2,882
Hello All, After trying to transfer some field changes on the safety scanner microscan3, and verifying, the device is stuck at .... waiting for...
61
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
89
Hello, I'm looking for a dirt cheap digital display + input, that would be wired to an analog input and analog output. This would be for my home...
266
